"Don Y" wrote in message
I need a relatively stable timebase against which to calibrate
my own *local* timebase.
Assume *my* environment is reasonably well controlled (temp, etc.).
Also, assume I can make measurements over VERY long periods of
time (24/7/365 duty).
Ideally, I would like the choice of reference to be something
that user could trade cost/convenience/performance.
To that end, I've got a few basic ideas:
- local XTAL (too easy to "pull", no real advantage over TCXO)
- local TCXO (overkill -- hard to make this "optional")
- external PPS input from GPS (requires view of sky, expensive)
- network time service (hole in firewall, latency issues)
- LFC (low accuracy but dirt cheap, LONG integration periods)
To be clear, I am calibrating *time* -- beyond that is my own
concern.
Any other ideas I should entertain?
Thx,
All you need is a decent shortwave radio with a decent antenna that can pick
up 5000 Hz, 10,000, 15,000, 20,000 Hz. Depending on the time of year;
different frequencies will travel to you home local. The atomic clock in
Bolder Colorado transmits the time on these frequencies, one second ticks.
You will have to compensate for your distance away from Boulder Colorado of
course to get a precise time. There are also some digital clocks that pick
up 60 Khz which is a sync frequency also for the atomic clock in Boulder
Colorado.
Shaun
