Hoping someone might take a minute to a double-check that the solid state relay I found (AQV101) on digikey meets the below requirements.
This SSR must:
-Work with a 3V control input signal that can supply at most 1mA. The documentation states that the SSR needs a 2.3V signal, but I'm not sure if that's a lower bound. The development board that I want to control the SSR outputs a 3V signal, at max 1mA.
-The SSR must support a 500mA load at 12V (solenoid valve). I know the SSR is rated for 700mA, but I'm worried about an inrush of current when the circuit is made. Is this something I should worry about?
*Note that I'm looking at the DC-input/DC-output version, AQV10 series*
http://www.digikey.com/product-detail/en/AQV101/255-1546-5-ND/570684
http://pewa.panasonic.com/assets/pcsd/catalog/aqv-dip-low-on-resistance-catalog.pdf
Ivan
This SSR must:
Ivan
