SSB newbie questions
Discussion in 'Boat Electronics' started by Martin, Jun 9, 2004.
  1. Martin
    Martin Guest
    I bought a new Icom 710 and Icom antennae tuner at an auction last year and
    I am just getting around to fit it. Our plan is to take off to the Med and
    possibly transatlantic in a couple of years time.
    I have just had an insulated backstay fitted and now need some advice on the
    electrical connections.
    What sort of cable should I use between the receiver and tuner and also
    between the tuner and antenna? How is the connection between the cable and
    the backstay best made?
    What should I do about earthing the tuner and receiver?
    If I need ground plates and so on this can wait until we lay up out of the
    water next winter, for the time being I shall be using the rig for listening
    only, so suggestions for an interim solution would also be useful
    Finally can anyone recomend a beginners book on this whole subject, so I
    don't ask any more probably silly questions
    thanks
    Martin
  2. I have just asked essentially this question here and in other places. I
    know little radio theory, which will probably help. Here is my
    distillation of the responses. Apologies to the locals here who clearly
    know far more than I do and tend to loose the uninitiated very quickly.
    I hope they don't mind me using their responses and those of others here.
    For connecting your tuner to your backstay most UK-based installers use
    the centre conductor of RG213U coax, having stripped off the outer
    screen and insulation. To make the connection at the backstay they wrap
    it round, clamp it with 2 or more ss jubilee clips and plaster the whole
    lot in self amalgamating tape. Keep it as short as possible, ie put the
    tuner very close to the backstay. Make sure you keep a space between the
    wire and any grounded metal; I am about to use plastic water pipe as a
    stand-off between the non-insulated bottom part of the backstay and the
    wire for this purpose.
    Between receiver and tuner use intact RG213 with standard well made
    pl259 connectors.
    For listening only, grounding to immersed metal such as seacocks is OK.
    Icom America have some very useful PDFs here
    http://www.icomamerica.com/downloads/default.asp.
    HTH
  3. Martin
    Martin Guest
    Just want I wanted - thanks very much
