SRAM Power Consumption
Discussion in 'Electronic Design' started by Patrick, Apr 30, 2007.
  1. Patrick
    Patrick Guest
    Hi
    I have got an SRAM Cache with 512 Cache Lines each 16 Bytes long with
    associativity of 1.
    For storing one bit I use a 6T RAM Cell. I used HotLeakage to estimate
    the power consumption for an
    0.07 process. The leakage cell_data for one 6T RAM Cell is calculated
    by the leakage of an nmos plus the leakage of
    a pmos transistor. The bitline leakage bitline_data for one cell is
    the leakage of an nmos transistor. This value has then be multiplied
    by the number of ports ->
    power_leakage_cache = (cell_leakage + bitline_leakage *
    number_of_ports) * 16(Bytes per Line) * 8 (Bits per Bytes) * 512
    (cache Lines in total)
    In other words, if all the cache would contain useful data in each
    line I get the following results:
    tagarray_power (W): 0.0021203
    datarray_power (W): 0.00512072
    In other words, one cache line consumes 10nW. Can this be possible or
    did I miss something?
    Cheers!
