Square wave input, PWM output?
Discussion in 'General Electronics Discussion' started by rsajan1, Apr 1, 2011.
  1. rsajan1
    rsajan1
    Nov 3, 2009
    Hi folks,
    I'm trying to find an IC or simple circuit that gives a pulse width modulated signal for a DC voltage input. For example, the input to this would be a square wave alterating between 0 and 5V. When the input is 0V, the output is 0V but when the input is 5V, the output should be a 0-5V square wave with a controllable frequency.
    The input comes from a comparator, maybe there are comparator ICs that have this as an in-built function? I cant seem to find any.
    Thanks!
  2. rob_croxford
    rob_croxford
    262
    Aug 3, 2010
    Do you want to vary the Frequency or the Duty cycle?? PWM is generally a variance in duty cycle to control the gate pin of a swtiching device, for instance. Or it can be used to vary the direction of a servo motor...
    What is your application?
  3. Iron Will
    Iron Will
    16
    Jun 11, 2012
  4. BobK
    7,682
    1,686
    This is contradictory. An input cannot be a DC voltage AND a square wave.
