square wave amplifier.
E
etexp2m2g
I need a simple square wave amplifier for a project. It needs to amplify a
Square wave 6 to 12 X in the 72 MHZ Band. Can anyone email me a schematic
or refference the same?
thanks
John Popelish
thanks
There is no such thing as a perfect square wave, in practice. How
much output voltage swing and what rise and fall time do you require?
And what load impedance must this amplifier drive?
D
Don Pearce
thanks
You can't have a square wave in a band. You need a response to DC to
preserve the flat tops, and a response to infinity to preserve the
vertical sides. So you need to specify what you will tolerate in rise
time and droop to arrive at an amplifier.
d
Pearce Consulting
http://www.pearce.uk.com
C
Chaos Master
etexp2m2g ([email protected]) said those last words:
thanks
What will be the impedance of the load?
[]s
© Chaos Master. | "I've tried so hard to tell
My Evanescence HP is at: | myself that you're gone
http://marreka.no-ip.com | And thought you were still
(most often offline... ) | with me..."
------------------------- -- Evanescence, "My Immortal"
T
Tam/WB2TT
thanks
Do you actually need a linear amplifier, or could you settle for an output
that is at a larger fixed amplitude?
Tam
