John Fields
My thinking was that with a simple single-pole lowpass with a
square-wave input:
SQIN>---[R]--+--->OUT
[C]
GND>---------+--->GND
You wind up with an integrator which merely charges and discharges
the cap as the square wave makes its excursions.
To get the lowpass to work here, the corner frequency
needs to be just above the 1 kHz square wave frequency.
An RC circuit like the above is only a good integrator
approximation if its time constant is long, such that the
effective corner is well below the input frequency.
You're joking, right?
If you start screwing around with the time constant all you'll wind
up doing is changing the output amplitude and waveshape, which will
_never_ resemble a sinewave, no matter what you do.
