square to sine converter
Discussion in 'Electronic Design' started by Kubicki, Sep 8, 2003.
  1. Kubicki
    Kubicki Guest
    Hi all
    I'm looking for a circuit that accepts a squarewave input of, say, 1 to 15
    Mhz and outputs a sine wave of the same frequency as precise as possible.
    Thanks to all.
    Alle.
  2. Make a sine wave VCO, the output of your VCO is the output of your circuit.
    Take the sine to a schmitt-trigger and XOR this with the input signal, low-
    filter the XOR output to control the VCO.
    Just a PLL with some extra's.
    Do a lot of calculations before you start, might be a bit hard to get the
    PLL stable over the complete range from 1..15 MHz.
    Good luck.
  3. D. Ford
    D. Ford Guest
    Would be much easier with a triangle wave driving a pair of reversed diodes
    in parallel and a limiting resistor. This would give a sine approximation
    with few percents of harmonic distorsion.
    What is your source?
    Fordy
  4. Kubicki
    Kubicki Guest
    Thanks a lot Jeroen!
    Alle.
