square tactile switch
Discussion in 'General Electronics Discussion' started by qweets, Apr 10, 2012.
  1. qweets
    qweets
    48
    Sep 26, 2010
    hello : )
    i am concidering using square led tactile switches for my project box ( as there seems to be more of a selection , actually i havent seen a round one yet? )
    cuting a square hole in a piece of metal to align perfectly with the pcb board and switch with stand off mounts, pheew, that seems difficult. perhaps snap in mount and just soldering wires to the tags would be safer?
    perhaps someone has experiece with led buttons on project boxes? or knows of a square hole puch that works well with a particular brand of switch?
    thanks for any help : )
  2. shrtrnd
    shrtrnd
    3,808
    511
    Jan 15, 2010
    If it's a one-time job, Radio Shack sells a 'nipper' that cuts square holes.
    You drill a hole, the nipper inserts into the hole, and you 'nip' the round hole
    into a square shape with the hand-help device. It looks like a pair of pliers, but
    is designed to nip at material to fashion a square hole.
  3. qweets
    qweets
    48
    Sep 26, 2010
    thanks, there may be a fair few to do, so i might need to change to a chassis mount type
    button like this below, it has a round hole and a square top.
    :http://uk.mouser.com/ProductDetail/...=Ss9ZrulIkegsEuw03TQCkx8VtpCoKC5CwXLTiygaX/U=
    a very deep button unfortunately , so to acomidate all consles. expensive too. eeek.
    i also have 30 smaller buttons to fit on my box. i'll have to try round tactile pcb types and hope i drill all the holes as perfectly aligned to the pcb as i can.
  4. shrtrnd
    shrtrnd
    3,808
    511
    Jan 15, 2010
    Yes, if you can, get a switch that mounts flat on the board, or will mount in a round
    hole. What you need if you do a lot of square holes in chassis, is what is called a
    'chassis punch', in the size you want. They're kind of pricey, but if you do a lot of
    one particular size, that's the way to go.
    'Greenlee' is one company that makes 'chassis punches', but there are others.
