SPST tact switch and rotary encoder with push switch
Discussion in 'Troubleshooting and Repair' started by Hagstrom, Feb 14, 2017.
  1. Hagstrom
    Hagstrom
    3
    Feb 14, 2017
    Hi!
    I'm trying to fix my Digitech RP500 guitar multieffects unit that has broken Tone library encoder and Edit switch. I contacted Digitech and they said I should contact distributers because Digitech doesn't sell spare parts directly. Distributers failed to obtain the parts so I asked digitech for specifications of the parts I need. This is what I got for an answer:
    The Tone Library encoder is a 12mm 24 detent rotary encoder with a 25mm D shaft, vertical mount, and it has a push switch in the shaft.
    The edit switch is a SPST tact switch, 50mA, 12vDC Radial AI type.
    I searched online for the parts (Ebay, Mouser, etc...) but didn't find the exact models. If anyone could provide the direct link where can I order those parts online, I would be so greatfull!
    Z.
  2. (*steve*)
    25,499
    2,839
    Try searching on digikey
  3. Hagstrom
    Hagstrom
    3
    Feb 14, 2017
    Standard package on digikey is 75 pcs. for encoder :(
  4. (*steve*)
    25,499
    2,839
    But you have a part number. Try mouser, RS, etc. and see if they have it (or one similar) with a smaller order qty.
  5. Hagstrom
    Hagstrom
    3
    Feb 14, 2017
    Allready did try Mouser, RS, etc.... Shipping costs are just to much. Item is about 2$ and shipping is above 35$ :(
    BTW, I didn't find the part number for the SPST tact switch :(
