spring centered changeover switch
Discussion in 'Datasheets, Manuals and Component Identification' started by morphingstar, Aug 22, 2012.
  1. morphingstar
    morphingstar
    56
    Mar 1, 2012
    Hi
    the switch to be replaced is about 1/2 inch, a little more.
    1 lever, manually operated
    3 soldering contacts
    Normally both open
    Move lever one way close 1 contact
    Move lever the other way closes the other contact.
    Who sells these in very small quantities.?
    The ideal switch has a large angle being closed, not just at the end of movement, and will not overshoot when suddenly released.
    thanks
  2. Harald Kapp
    11,160
    2,550
  3. morphingstar
    morphingstar
    56
    Mar 1, 2012
    toggle switch mom-off-mom
    yes, you understood perfectly-
    Newark came up 0, and Newark did not ship to Mexico some time ago, guess it is still the same.
    At least I learned the proper description.:)
  4. CocaCola
    CocaCola
    3,635
    5
    Apr 7, 2012
    Generally these will be labeled like this
    (on)-off-(on) or mom-off-mom <- these designate a momentary with a return to center
    on-off-on <- this will stop and latch in any of the three states
Similar Threads
Loading...
