Split Voltage
Discussion in 'General Electronics Discussion' started by renfley, Mar 7, 2013.
  1. renfley
    renfley
    5
    Mar 6, 2013
    Hey guys.. quick question for you..
    My goal is simple, i want to used a laptop power cord to power two 5 volt devices,
    one being a raspberry pi and the other is the lcd control board.
    Does anyone have any ideas or solution they could offer?
  2. davenn
    davenn Moderator
    13,930
    1,981
    well for a start tell us what is the voltage rating of the Laptop power adaptor ?
  3. renfley
    renfley
    5
    Mar 6, 2013
    the adaptor in question is an old IBM
    Input: 100-240v ~ 1.5A-0.9A 50/60hz
    Output: 16v 4.5A
  4. Harald Kapp
    11,965
    2,798
    You will need a 5V regulator. Otherwise you will fry your boards.
    What are the power requirements of the boards?
    For up to ~100mA a simple linear regulator based on an 7805 can do.
    If you need more than ~100mA per board you will want to use a switch mode regulator like e.g. this one.
  5. renfley
    renfley
    5
    Mar 6, 2013
    well the first board is the M.NT68676.2A MONITOR CONTROL BOARD which is
    Requirement 12V DC/12V(built)/12V,5V(built in)/12V,5V,5VSB(built in)
    and then i need 5v for the raspberry pi! \
    The link for the Monitor control board is here
    http://www.vslcd.com/Specification/M.NT68676.2A.pdf
  6. Harald Kapp
    11,965
    2,798
    In your first post you mentioned 2 5V devices. According to your latest satement, you will need two separate regulators: 1*5V + 1*12V.
    By power requirements I meant: what is the current consumption of the boards?
  7. BobK
    7,682
    1,688
    The Raspberry PI can be powered by any 5V USB plug charger. You can get these for a couple of bucks.
    And are you sure you need that monitor board? The Raspberry Pi has hdmi video built in.
