spice3 simulation of VCO
Discussion in 'CAD' started by ICguy, Jul 12, 2005.
  1. ICguy
    ICguy Guest
    Why can not I see the result of AC analysis of the VCO in spice3? I can
    observe that there is an oscilation in transient anaylisis.
    Thank you
  2. Basically, because your VCO model is not modeled, as such, in the AC
    domain. AC analysis doesn't do that sort of 'stuff'!
    Charlie
  3. Jim Thompson
    Jim Thompson Guest
    Sure it does, Charlie. Just do a loop gain (.AC) analysis.
    Best performed using my LoopGain technique, as described on my website
    ...Jim Thompson
  4. ICguy
    ICguy Guest
    Thank you both for your reply. I will try the loop gain analysis...
  5. Jim Thompson
    Jim Thompson Guest
    Make sure you use enough steps per octave/decade/whatever in your .AC
    analysis. Otherwise you'll completely sail right over the resonances
    of the crystal.
    ...Jim Thompson
  6. ICguy
    ICguy Guest
    I tried the .AC analysis on VCO, the output is still zero. However, if
    some noise is added to the VCO, then I can observe an nonzero output of
    the VCO in AC analysis. Does this mean that the VCO is not oscilating
    at all? if so, why I can observe an oscilltion in .TRAN analysis?
    Thank you
  7. Jim Thompson
    Jim Thompson Guest
    Do you know how to do a .AC analysis? Maybe post your schematic to
    <alt.binaries.schematics.electronic>
    ...Jim Thompson
  8. ICguy
    ICguy Guest
    Isn't . AC analysis like the following?
    ..AC dec No. fstar fstop
    I couldn't find <alt.binaries.schematics.electronic>.
  9. Jim Thompson
    Jim Thompson Guest
    Go to my website and E-mail me a schematic, PDF preferred but an
    LTspice listing will also work, and I'll take a look.
    ...Jim Thompson
