SPICE source code.
Discussion in 'CAD' started by Chaos Master, Apr 10, 2004.
  1. Chaos Master
    Chaos Master Guest
    Hello
    I want to compile SPICE3F5 under FreeBSD. I know about the "Ports" thing
    (/usr/ports) but I want to compile from the sources.
    Where can I find source code of SPICE3F5 (plain SPICE, no XSPICE)?
    thanks
  2. : Hello
    : I want to compile SPICE3F5 under FreeBSD. I know about the "Ports" thing
    : (/usr/ports) but I want to compile from the sources.
    : Where can I find source code of SPICE3F5 (plain SPICE, no XSPICE)?
    Why not compile ngspice? It's basically SPICE3f5 cleaned up and
    provided with a GNU compliant configure/make system.
    http://ngspice.sourceforge.net/
    Make sure you download version 15, which is only available from CVS:
    http://ngspice.sourceforge.net/cvsaccess.html
    If you don't want XSpice, don't say --enable-xspice at configure time.
    Stuart
  3. Chaos Master
    Chaos Master Guest
    Qu0t1n a 31337 h4ck3r 14b3113d Stuart Brorson []:
    Will take a look.
    Thanks!
