Spice simulation problem (option pivot)
Discussion in 'CAD' started by [email protected], Nov 25, 2006.
  1. Guest
    Hello,
    I'm simulating a Sigma-Delta modulator in Hspice and I get the
    following error:
    *error*: maximum conductance on node 0:ecompar =(
    0.0000D+00)
    is less than pivtol. check hookup for this node. set option
    nopiv and rerun.
    I set .option NOPIV and rerun, but still get the same message. I am
    using voltage controlled sources as opamps :
    Rin in integr_n 1k $interg_n =>negative input of
    intergrator's opamp
    Eintegr compar_n 0 OPAMP GND integr_n $compar_n =>negative input of
    comparator's opamp
    Cint integr_n compar_n 30p
    Rintegr integr_n fdb 1k $fdb =>feeback from the latch
    Ecompar latch_in 0 OPAMP GND compar_n MAX=5 MIN=0
    the rest of the circuit is 8 mosfets implementing a latch.
    Does anyone have any idea why I get this message, and why setting the
    option NOPIV is ignored??
    George ( mail: giorgos.puiklis at gmail.com)
  2. Fred Bartoli
    Fred Bartoli Guest
    a écrit :
    I didn't check the rest but the option syntax is
    ..options ... (notice the final 's').
    On my spice (which isn't hspice) the misspelled .option line is simply
    ignored without any warning.
