SPICE dynamic transformer simulation
Discussion in 'Electronic Design' started by JT, Nov 16, 2006.
  1. JT
    JT Guest
    I need to create a transformer subcircuit of which the primary
    inductance (# primary turns) can change based on the value of the input
    voltage. My SPICE experience amounts to point and clicking in
    circuitmaker, but I'm sure I need to allow the subcircuit to accept
    the V parameter and use it to calculate L1 internally? Can anyone
    nudge me in the right direction?
    JT
  2. JT
    JT Guest
    Sorry, the input parameter is "some" voltage, not the actual voltage
  3. qrk
    qrk Guest
    Parameter statement? PSpice, LTspice and others support parameter
    (.param) statements. Hopefully Circuitmaker supports .param.
  4. Joel Kolstad
    Joel Kolstad Guest
    Does it have to be "some" voltage? Or can it be "some parameter?" -- In
    which case you can just use the parameter's name as the value for the
    transformer models' magnetizing inductance.
  5. Fred Bartoli
    Fred Bartoli Guest
    JT a écrit :
    With such initials you should be up to the task :)
    OK, one way is to copy the input port voltage across an inductor using a
    VCVS and measure the resulting current (with a 0V voltage source).
    Then you reflect this current on the input port with a B current source,
    applying the operation you want.
    Just beware that doing so you can easily end up with non physical
    devices (particularly if you're modelling non linear components) if
    you're not careful enough.
