Spice diode model
P
Paul
Does anyone have an accurate spice diode model for transient analysis
that would include shot and Johnson noise?
Thanks very much,
Paul Lowrance
P
Paul
Thanks very much,
Paul Lowrance
After just submitting my post I can see how it's perhaps unclear. I am
not looking for a spice diode model; e.g., .MODEL HSMS-285x D
(IS=3E-6,CJO=0.18E-12,VJ=.
35,BV=3.8,IBV=3E-4,EG=0.69,N=1.06,RS=25,XTI=2,M=0.5)
What I'm trying to do is add diode noise to a transient analysis
simulation. Current causes shot noise, and diode resistance causes
Johnson noise.
So far I've been able to add noise to my resistors, which is an easy
task. For LTspice I came up with -->
Johnson noise source, in series with the resistor:
V=white(time*BW+{flat(9999999)})*3.017494931E-11*((T*BW*R)**.5)
BW is bandwdith.
T is temp is Kelvin
R is the resistance of the resistor.
The last task is to add noise to diodes, perhaps not such an easy task.
H
Helmut Sennewald
Johnson noise.
BW is bandwdith.
T is temp is Kelvin
Hello Paul,
Are you the same Paul with a similar question in
sci.electronics.design ?
I have just send the same answer to sci.electronics.design.
unclear. I am not looking for a spice diode model; e.g.,
.MODEL HSMS-285x D (IS=3E-6,CJO=0.18E-12,VJ=.
analysis simulation. Current causes shot noise, and diode
resistance causes Johnson noise.
is an easy task. For LTspice I came up with -->
BW is bandwidth.
T is temp is Kelvin
an easy task.
Hello Paul,
Shot noise is equal sqrt(2*q0*Id*BW).
Just use I(D1) in the formula of a current noise source Bi, I=white(....).
This noise current source has to be connected in parallel to the diode.
It would be more correct to use a Gauss noise source. A Gauss
noise source can be made with a few independent random noise
sources or with the Box-Mueller method.
Normally a noise analysis in SPICE will be done with
the AC .NOISE analysis. The main reason is the small ratio of
noise compared to the signal. A time domain simulation can have
accuracy limits above your expected noise level.
Best regards,
Helmut
