spice and Capacitors
Discussion in 'Electronic Design' started by [email protected], Apr 17, 2007.
  1. Guest
    Hello,
    I realize that when spice tries does a transient analysis it has to
    generate a matrix of some kind in which in it solves for the various
    for the various voltages and currents. I also realize that spice must
    use some kind of modified nodal analysis to do all it's calculations.
    Thus spice should know all the capacitances at every circuit node
    within the circuit. At least it must "know" what they are at some
    point when it generates the matrix of equations. The question I have
    is, how can I ask spice what all these capacitances are? Is it
    possible to get the parasitic capacitances to printed out as well as
    what it thinks the capacitances should be?
  2. Mike Monett
    Mike Monett Guest
    Yes, you are correct. Spice needs the correct parameters to solve the
    equations. The parameters are in the model for each component.
    For example, the LTspice model for a capacitor includes values for series
    resistance and inductance, parallel resistance and capacitance, plus other
    miscellaneous parameters such as voltage and rms current rating, etc. There
    are default values for each component that you can find in the
    documentation.
    You can get very strange results in some circuits if you do not enter the
    correct values for these parasitics. For example, the default series
    resistance for an inductor may be extremely low. If you use the induictor
    in a resonant tank, you will get abnormally high Q, and the circuit won't
    perform the way it whould.
    Many spices also allow you to specify a nodal resistance to ground if one
    is not included in the circuit. This is usually high enough that it won't
    have any effect on a circuit.
    Others may be able to answer your question in more detail.
    Regards,
    Mike Monett
  3. Tom Bruhns
    Tom Bruhns Guest
    Are you saying that you think Spice should be able to figure out, with
    no help from you, what the parasitic capacitances are in a circuit you
    could build in an infinite variety of physical implementations, each
    with a different set of parasitics?? Nooooo, I don't think so!
    Parasitic capacitances are the result of the physical dimensions of
    the conductors and dielectrics in your circuit. For example, a pad
    for a surface mount part will have a certain capacitance if there is a
    ground plane on the next layer down, 4 mils away on a 12 layer board,
    and quite a different capacitance on a single sided board with no
    ground plane.
    I do hope I'm misinterpreting what you are asking! If I'm not,
    perhaps my answer above will give you a hint that in circuits where
    parasitic effects are important, you need to pay close attention to
    them, and make sure you get them right. Same applies to parasitic
    inductance, leakage resistance in high impedance circuits, and the
    like.
    The only capacitances in a Spice circuit are the ones you put there.
    It certainly is easy enough to ask what the impedance between two
    nodes is in the circuit you enter, and in fact you can pretty easily
    write an expression to display the impedance as an equivalent
    resistance in series with an equivalent inductance or capacitance.
    The impedance is simply the voltage difference between the nodes
    divided by the current through the network connecting them. Beware of
    other current paths; this works best if the network only connects to
    those two nodes and nothing else.
    Cheers,
    Tom
    Cheers,
    Tom
  4. Guest
    Hello,
    Sorry, perhaps I worded this question incorrectly. I don't expect
    spice to able to calculate parasitic capacitances that put there. I.e,
    if I model an inductor, and I specifically place a parasitic
    capacitance within the model of the inductor then spice knows it
    exists and should take into account. Usually I will place all the
    parasitics on the schematic and some of them should be implied as
    well. (When you place a transistor, you should tell spice only what
    the unit gate capacitance is and it should be able to figure out the
    total gate capacitance...correct?) However when the schematic gets
    large, it is quite easy for me to forget all the parasitics that are
    connected to that specific node, but spice should know what those are.
    I was wondering, if I could spice to spit it for me, so that I don't
    accidentally forget something.
    Best Regards,
  5. Tom Bruhns
    Tom Bruhns Guest
    WHY do you think Spice will know about parasitics if you don't tell
    it?? I'll repeat, Spice only models what you explicitly put into its
    netlist. If you think there is parasitic capacitance from one node to
    another (possibly to ground, for example) that's big enough it will
    significantly affect the performance of your circuit, then figure out
    how much capacitance there is in your physical implementation, and put
    it in the model. Spice does not work from a physical model, it works
    from a mathematical abstraction. It's up to you to make sure the
    physical world is accurately described by the information you feed
    Spice about your circuit. If you're dealing with semiconductor design
    there may be special issues someone like Jim Thompson (who posts
    regularly here) could help with.
    There ARE design programs that take into account the physical layout,
    treating printed circuit traces and pads as transmission lines with
    distributed capacitance and inductance. The Spice engine is not one
    of those. In some versions of Spice, including LTSpice, you can
    create a library of models of specific parts like inductors that
    include at least limited parasitic information like series resistance,
    shunt resistance and shunt capacitance. Capacitors in LTSpice can
    include parasitics. Spice models for semiconductors have lots of
    parameters to describe the semiconductor behaviour (including voltage-
    dependent capacitance, resistances you might wish were zero but are
    not, ...), but do not include package inductance, capacitance, and
    resistance. Some manufacturers' models of packaged semiconductors do
    include those effects.
    But if you accidentally forget to put a critical coupling capacitor in
    your circuit, would you expect Spice to tell you, "Hey, you forgot to
    put in a capacitor here. You probably want 0.22uF, so I put it in for
    you." No? Then don't expect it to think of what parasitics might be
    in your physical implementation that you left out of your model.
    Cheers,
    Tom
  6. Guest
    A netlist is a list of components showing which nodes each is
    connected to. My reading of your question is that you want a list of
    nodes showing which components each is connected to, or perhaps just
    listing nodes not connected to any capacitors or semiconductors.
    I am fairly sure that standard Berkeley SPice 3f4 has no command to do
    what you want, although I seem to recall that HSpice does.
    If you are using a Berkeley Spice derivative, you might use the
    'listing expand' command to produce a flattened netlist. Then use a
    scripting language such as Perl to parse this and produce your list.
    It would be tricky to get to handle devices with variable numbers of
    nodes perfectly. However, you probably don't need perfection.
    Charles
