Spi connections
Discussion in 'General Electronics Discussion' started by Rajinder, Feb 19, 2021.
  1. Rajinder
    Rajinder
    535
    10
    Jan 30, 2016
    Hi all,
    I am connecting a 4 wire spi to 4 wire spi.
    Master is a micro, slave is a temp sensor.
    Do I connect as follows
    SCLK to SCK
    SS to CS
    MOSI to MOSI
    MISO to MISO
    The micro is the master.
    Thanks in advance
  2. Harald Kapp
    11,968
    2,799
    @Rajinder : do you do any research yourself before coming to this forum?
    It's not that we don't want to help, but a bit of cooperation on your side is appreciated.
    Rajinder likes this.
  3. Rajinder
    Rajinder
    535
    10
    Jan 30, 2016
    Hi, I did some research and it said what I have mentioned on one website, but on another it was different, hence I wanted some clarification. That's all. Sorry.
  4. PETERDECO
    PETERDECO
    212
    53
    Dec 19, 2019
    I have limited SPI experience but it is my understanding the MISO (output) will connect to MOSI (input) for communications.
  5. Harald Kapp
    11,968
    2,799
    If you had said so and included the links to these sites it would have been clear to us that you had done some research which left you with doubts.
    No.
    MOSI is MasterOutSlaveIn and is named so on both master and slave.
    Same for MISO (MasterInSlaveOut).
  6. bertus
    bertus Moderator
    2,261
    840
    Nov 8, 2019
  7. PETERDECO
    PETERDECO
    212
    53
    Dec 19, 2019
    Thank you @bertus. That clarifies lots. @Harald a while back I used a uC to communicate with a chip using SPI. I connected the chip's MOSI (input) to the uC's SDO (output). That's the reason I thought the outputs connected to inputs.
