I bought a brand-new Fluke 75 DMM and it worked fine for more than a
year, with intermittent use, sometimes on weekends, not on a daily
basis. Well, more than a year later, I turned it off but it wouldn't
turn off. Something went wrong with the rotary switch. So I packed
it up and shipped it to Fluke for repair since it was under warranty
for 3 yrs. It came back repaired and cal'd, and has worked fine for
more than a decade. So the moral of the story is that you can still
get a dud even when buying a very reputable and well-made DMM. And it
helps to have a good warranty.
And I would avoid those meters like the one that Radio Scrap sells,
even tho they're okay for home use. If you read the back label, it
says not for commercial use, or something to that effect. In other
words, if you use it on the job, they won't warranty it. I assume
that means it's light-weight and under-built.
I bought a half dozen DMMs from Futurlec for 6 bucks each, _with_
battery(!) I opened one of them and the test leads didn't have
continuity, so I used some other leads laying around. The meter
worked okay, but the test leads are crap. But at that price I didn't
expect much. If one breaks, it ends up in the scrap heap. ;-)
I still have five more.
