Speed
Discussion in 'Electronic Basics' started by Abstract Dissonance, Mar 10, 2006.
  1. How does speed of data(in MB/s say) related to speed in Hz? Is there a
    simple relation? It would seem that, say, if I'm transfering something at
    100MB/s then it would be equivilent ot 100 HZ? (since a "cycle" is like a
    bit (although I guess that could be off by a factor of 2 depending on what
    you call a cyle)?)
    The reason is that after reading some of AOE it I get the impression that
    its very difficult to get speeds about 100Mhz and it takes special design to
    even do that... It does mention that there are transistors/techniques that
    can theoretically get up to 18Ghz but that they are very expensive. So how
    do we have 10Gb/s connections and now even up to 1Tb/s connections using
    fiber optics? Is AOE out of data about this sorta stuff or am I missing
    something? Or is this just "mumbo-jumbo" when they talk about these numbers
    since you can have many "channels" that add up to that speed but in reality
    the speed is really only a fraction of what they say?
    Jon
  2. w2aew
    w2aew Guest
    It's not really possible to directly relate datarate (like Mb/s) to
    signalling speed (like MHz) without including the type of encoding or
    format of the data. The datarate refers to the rate of transmission of
    the actual "information", while the signalling speed refers to the
    signal rate or speed in the media.
    For example, consider unencoded NRZ data transmission. NRZ data means
    non-return-to-zero. In other words, it means that each bit stays at
    its value (1 or 0) for the duration of the bit interval. The highest
    frequency of signalling is when you're sending a 1010101010 pattern.
    At 100Mb/s, each bit interval is 10ns. The transmitted signal will
    look like a square wave with a period of 20ns (a 1 followed by a 0).
    Thus, the frequency of the square wave is 50MHz. However, since it is
    a square wave and not a sine wave, there are odd harmonic frequencies
    present too (150MHz, 250MHz, 250MHz, etc.)
    RZ signalling is where each bit returns-to-zero at the middle of the
    bit time. Thus a 1 is transmitted as a 1 level or 1/2 the bit time,
    then it goes to 0 for the 2nd half of the bit time. A 0 is transmitted
    as a zero for the entire bit time. In this format of signalling, the
    highest frequency is present in the transmission of a continuous string
    of 111111's, because this will be a transmitted as a squarewave at
    100MHz if the datarate is 100Mb/s.
    The above examples show that even unencoded data, sent at the same
    datarate, result in dramatically different signalling rates in the
    transmission, depending on the format of the data.
    There are many, many encoding schemes that are used to transmit digital
    data, and each of them transform the spectrum of the data signal into a
    different spectrum for the transmitted signal. In general though, you
    don't get anything for free. This means, that the faster the
    "information" rate or data rate, the more bandwidth or speed of
    signalling will be needed.
    The difficulty in achieving high speed digital data transmission is
    directly related to the "media" which is used to carry it - i.e.
    twisted pair wires, coax, printed circuit traces, fiber optic cable, RF
    signals, etc. Each type of media has its own advantages and
    limitations when it comes to its use for data transmission.
    AoE is a little out of date with respect to this - but you have to take
    into account the context of where the statement was made. If they were
    talking about driving much greater than 100Mb/s on twisted pair over
    long distances - yeah, that's not trivial but it is done everyday.
    However, 100Mb/s is child's play for fiberoptics for great distances.
    Serial fiber optic transmission is commonly done at 10Gb/s. Many such
    10Gb/s signals can be put onto the same fiber simultaneous (at
    different optical wavelengths, or "colors"), thus achieving overall
    throughput that's much greater. Single channel transmission can also
    be done at many hundreds of Gb/s on fiber too - but there isn't really
    much widespread use of that yet - since much of the ulta high speed
    fiber transmission is standards based, and there aren't popular
    standards out there for too much beyond the 10's of Gb/s per channel,
    yet...
  3. yeah, but encodings are variable and will almost always increase the
    "Bandwidth".... but are they used to increase the numbers? i.e. is a 10Mb/s
    connection 10Mb/s raw or based on some encoding scheme? (I would expect raw
    cause if you sent already compressed data then the throughoutput would be
    drastically lower than what "they" say it is).
    But are these raw speeds(non encoded?) or are they avg speed for some ideal
    signal? Cause it still makes me wonder how one could get up to 100Gb/s as
    that translates into 50Ghz or so for the same example you talked about
    above... what kinda devices can do this? is it just very specialized
    transistors like GaAs that can do up to 18Ghz or so?
    The basic point I was getting at is frequency = 1/datarate?
    So a 1TB/s is basicaly working with a period of 1ps per "bit" which gives a
    frequency of about 1Thz if we are using 1 cycle as a bit? Ofcourse
    depending on your scheme you could reduce this to whatever you want.
    So the point is how can they even handle 1Thz? What new techniques are
    there that can do stuff like this? Is it just all a matter of optimization
    and efficiency or are there new components to handle this?
    Like in AOE they go in and talk about techniques to increase the
    bandwidth/speed of transistors and such(the Millner effect or whatever) but
    its still based on the original transistors design... he does mention GaAs
    but that only gets to 18Ghz or so.... is there some new materials that can
    do 1Thz or are these just modifications of something that has already
    existed for awhile?
    Jon
  4. w2aew
    w2aew Guest
    Jon,
    Encoding schemes are used to overcome certain problems (long run
    length, transmission spectra, clock recovery, etc.). While many
    encoding schemes increase the BW, there are many that also decrease the
    BW required. A good example is your old 56K modem. This uses an
    encoding scheme that squeezes 56kilobits/sec through about 3KHz of
    bandwidth on the phone line.
    I would say that in most cases, when someone quotes a datarate, then
    they are referring to the actual information rate, or resulting
    bits/sec of real information, rather than the encoded or transmitted
    baudrate.
    In basic, digital baseband serial transmission, without encoding, the
    basic frequency is equal to 1/2*1/bitrate, as explained above.
    In the 10Gb/s optical transmission I mentioned - this is basically the
    transmission rate. There's a standard for 9.953Gb/s transmission,
    which includes the header, framing info, etc., so the actual "data
    information rate", or "payload" rate is slightly lower. Many
    transmission systems include forward error correction, which adds bits
    and thus increases the signally rate for the same payload rate. Common
    FEC rates are in the range of 11.5Gb/s to 12.5Gb/s for the same payload
    rate as the unencoded 9.953Gb/s basic rate. The optical transmission
    is most commonly done with simple two-level transmission (i.e. light=on
    for a 1, light=off for a 0). Thus, for 10Gb/s, the maximum optical
    square wave frequency is 5GHz.
    Mainstream silicon bipolar and silicon CMOS process can produce devices
    that support serial bitrates in excess of 10Gb/s. There are exceptions
    of course. In many cases, more high-performance processes such as
    silicon-gemanium, galium-arsenide, or other heterojunction
    semiconductors are used for >10Gb/s. There are processes that produce
    devices capable of operating at speeds in excess of 100Ghz.
    There are ways of directly handling ultra high speeds like 1THz, but
    generally these speeds are acheived in a parallel fashion - lots of
    high speed signals processed simultaneously.
  5. Ok, Thanks for the indepth explinations.
    Jon
