U
Udo Zaydowicz
Hello,
I've got a problem with the above-mentioned f/U-converter (8-pin
version) using it as a speed switch.
Given is a car's speed signal (symetrical rectangular signal). Switching
should occur at a frequency of appr. 36 Hz. The speed switch is build
iaw the example in the datasheet/application note. The speed signal is
connected to the IC-input through ac coupling as described in the
application notes.
Schematic: http://www.zaydowicz.de/Forum/Schaltung.jpg
Well, it is switching as designed. However, if the car is decelerated to
a stop (frequency -> 0), the converter switches sometimes just after the
car stops.
Quite obvious, this happens each time when the positive flank of the
speed signal is 'caught' and the car stops before the negative flank.
The speed signal itself is clean, not spikes, no disturbences etc..
The picture at http://www.zaydowicz.de/Forum/Signal.jpg should
illustrate this (purple: speed signal, yellow: LM2907 f-input).
Can anybody help me with that?
Many thanks in advance, Udo
application notes.
car stops.
