spectrum
F
Flagpole
hi
If solar cells currently absorb 20% - 30% of the suns energy, what spectrum
does this fall under? does the limitation of the spectrum captured the
reason for such low efficiency?
thanks for help
S
Sylvan Butler
More like 10%-15%, unless you count the heat...
Solar photo-voltaic cells work because the incoming photon knocks loose
an electron. One definition of electric current is flowing electrons,
thus the photon causes current to flow.
This only works if the incoming photon has enough energy to knock the
electron loose. So only the higher energy light is converted to
electricity, the lower energy light just results in heat. (ultraviolet
end of the spectrum is higher energy than the infrared end.)
You only get one electron per photon, so if a photon has more energy
than needed, the rest of the energy results in, you guessed it, heat.
Research continues into materials with a lower bandgap energy (so lower
energy light can knock out electrons) and also higher bandgap energy, as
well as making multi-layer cells so that different photons can knock
loose electrons from different layers.
All alternatives are fantastically expensive compared to the old standby
-- silicon. Thus silicon remains the material of choice for commercial
solar PV cells / modules / panels.
sdb
R
Robert Morein
Sylvan Butler said:
spectrum
That is approximately true, but the energy of the impinging photon has to
approximate the energy of the bandgap.
Commonly available solar cells are tuned for green light.
In fact, many multicrystalline cells are coated with an interference layer
that presents a blue color.
These cells are almost completely insensitive to that particular color,
since the blue color represents reflected light.
This interference layer is so chosen because it actually increases the
transmission of green light into the cell.
It also protects the cell from blue light, which causes slow degradation of
multicrystalline cells.
G
George Ghio
Flagpole said:
hi
Approx. 300 t0 1250 nm at the earths surface
R
Robert Morein
message
Thank you for your expert reply.
