[email protected]
Hello,
i want to do measurements with a FFT-spectrum-analyzer.
Assume, the displayed frequenzy range is 25.6kHz. I use 400 lines of
resolution. Thus, i have frequency points ever 64Hz (the frequency
bins are 64Hz sperated from each other). I use Hanning windowing.
Now, i change the frequency range from 25.6kHz to 6.4kHz. The
resolustion is still 400 lines. So the frequency bins are
6400/400=16Hz sperated from each other. The window is still a Hanning
one. But what is with the width of the window? Is ist constant in both
measurements? Or does it adapt to the frequency range? Is main peak
(from 0dB to 3dB) wider when the frequency bins are more far away from
each other?
Thank you in advance,
Jens
each other?
Jens
