Specs for Harris electronic flash chip?
Discussion in 'Electronic Repair' started by Samuel M. Goldwasser, Jan 3, 2009.
  1. I might have asked about this a couple years ago here goes again:
    Does anyone have specifications or has determined a pinout for
    the Harris 988754 IC, the micro strobe brain from electronics goldmine?
    At one point, I had gotten it to do something but never actually work
    properly, and blew up at least one of them in the process.
    Thanks!
    sam | Sci.Electronics.Repair FAQ: http://www.repairfaq.org/
    | Mirror Sites: http://www.repairfaq.org/REPAIR/F_mirror.html
    ignored unless my full name AND either lasers or electronics is included in the
    subject line. Or, you can contact me via the Feedback Form in the FAQs.
  2. N_Cook
    N_Cook Guest
    what sort of date ?
  3. 97
    Thanks!
  4. Franc Zabkar
    Franc Zabkar Guest
    Is this it?
    http://www.goldmine-elec-products.com/prodinfo.asp?number=G4584A
    Try searching for "photoflash charger" here:
    http://www.datasheetarchive.com/search.php?q=photoflash+charger&searchtype=default&p=1
    I didn't see any Intersil or Harris parts, but here is one datasheet
    for an 8-pin part that includes an application circuit:
    http://www.datasheetarchive.com/datasheets/Datasheet-029/DSA00513693.pdf
    It may give you some clues as to pinout and function.
    Have you tried tracing the circuit?
    - Franc Zabkar
