circuitdude
- Apr 2, 2012
- 4
- Joined
- Apr 2, 2012
- Messages
- 4
Hi all,
I would like some help with a project, but please note that I'm fairly new to the electronics world .
What I'm trying to do is a switch panel that is connected to a keyboard controller - just like in this video .
The only difference is that the panel will be for flight simulator use, so instead of that button, I will be using SPDT toggle switches.
The software that I am going to use does not require the key to be released for the certain action to take effect. However, if I want to switch back to the "off" position in-game the same key has to be pressed.
So, the question is, If I flip the toggle switch to the "on" position and flip it again to the "off" position, will it let the electric signals go to the controller even after it is switched to the "off" position ? .
If not, is there any other type of toggle switch that will do the job?
Or can I connect the same switch to multiple contacts on the controller?
Thanks in advance.
Thanks in advance.
