spdt short lever toggle
Wanted: Discussion in 'For Sale / Wanted' started by echidna, Feb 7, 2013.
Thread Status:
Not open for further replies.
  1. echidna
    echidna
    3
    Feb 7, 2013
    I've been trying for ages to source some spdt short lever on-on mini toggle switches here in UK like these at this site (they are out of stock and shipping is high):
    http://www.smallbearelec.com/servlet/Detail?no=792
    Can anyone point me in the right direction. I'll reluctantly go for on-off-on if available.
  2. oyvdahl
    oyvdahl
    15
    Oct 11, 2012
  3. duke37
    duke37
    5,364
    771
    Jan 9, 2011
    These look to be a common type of switch although they are often double pole, you do not have to use the other pole.
    In the UK you can try:-
    RS, Maplin (there are many local shops), Farnell, Cricklewood, Bowood, Potts (Derby, not far from the bus or train station).
  4. shrtrnd
    shrtrnd
    3,821
    519
    Jan 15, 2010
    The switch itself is a comon C&K Switch, here in the States.
    Look-up the C&K product line, and you can obtain the full designation for that switch
    (The toggle-lever length is part of the full switch part number).
    One you have the full part number, you should be able to find the exact replacement,
    or a cross to another manufacturer's equivalent).
  5. echidna
    echidna
    3
    Feb 7, 2013
    Thank you kindly for that information. I have been able to find exactly what i want from Digikey:
    100SP1T2B9M1QE-ND
    It would be great if i could source them in UK to avoid the shipping.
    The really important thing here is that short lever. The ones in the picture i sent is about 5mm, but i'd like some around 3mm as well.
    Thanks again.
  6. Jotto
    Jotto
    120
    Aug 24, 2012
    Why not just reduce the size of your toggle with a grinder?
  7. echidna
    echidna
    3
    Feb 7, 2013
    That is a good idea, but could it be made look good afterwards? They are often plated brass.
  8. Jotto
    Jotto
    120
    Aug 24, 2012
    If the appearance makes a big deal, go to a electrical supply house and get the rubber they use for coating hand tools and dip it in that or something similar. How it looks wouldn't be important to me, I would be more interested in function.
Similar Threads
Loading...
Thread Status:
