SPDT 5-Pin Relay
Discussion in 'General Electronics Discussion' started by euta226, Jul 8, 2013.
  1. euta226
    euta226
    3
    Jul 8, 2013
    Hello all,
    Very new to electronics and I purchased some relays the other day. Upon receiving them, I was a bit confused by the placement of the 5th pin (COM). It falls between two holes on a PCB and also could not be inserted into a breadboard. Is this normal for this type of relay (http://www.taydaelectronics.com/mini-relay-spdt-5-pins-6vdc-10a-120v-contact.html)?
    I had to drill a hole in my PCB to be able to mount it and had to use wires with alligator clips to be able to test it on a breadboard. Would anyone recommend a particular relay (SPST/SPDT) that you had no problem mounting?
    James
  2. CDRIVE
    4,960
    652
    May 8, 2012
    If you want to insure that the relay you buy will match a breadboard pattern you should look for DIP (Dual In-line Package) or SIP (Single In-line Package) footprint relays.
    Chris
  3. KrisBlueNZ
    8,393
    1,271
    Nov 28, 2011
    Hi James, and welcome to the Electronics Point forums :)
    The TE Connectivity V23079 relay series has all pins on a 0.1" grid and is available in a good range of voltages and configurations. And it's one of the cheapest available from Digikey.
    http://www.digikey.com/product-search/en?x=0&y=0&lang=en&site=us&stock=1&KeyWords=V23079
    Digikey have 31 variants in stock; seven of these are THT (through-hole technology). (The other 24 are surface-mount technology, SMT.)
  4. euta226
    euta226
    3
    Jul 8, 2013
    Thank you for the responses Kris and CDrive. I guess that saying about when you assume things really applies here, huh? :)
    Thanks CDrive, I'll pay more attention to the DIP/SIP specification on my next purchase.
    Thank you for turning me on to the V20379 line of relays Kris! I'll definitely use those on my next purchase.
    Glad I found this forum!
    James
