SPDIF to TTL
Discussion in 'Electronic Design' started by Dirk Bruere at NeoPax, Jun 7, 2010.
  1. Dirk Bruere at NeoPax wrote...
    That's a simple AC signal to DC logic conversion,
    .. AC ---||---+---| >O--+----
    I'd say, yes, in the absence of any signal, an HCU04 gate
    would do a better job of settling at 1/2 Vcc, and perhaps
    do so with less class-A current, but in the absence of a
    signal, who cares what happens? In practice, S/PDIF lines
    have a continuous AC signal, so this simplified circuit's
    feedback RC node should find the average of the incoming
    data stream. Also, the continuous huge signal means the
    gates won't have a class-A rail-rail current problem.
    s/pdif data doesn't have a 50% duty cycle, which gives me
    pause, but Andrew Kilpatrick, Randy McAnally and ESP =
    Rod Elliott swear by it, so it must be adequate. :)
    http://www.andrewkilpatrick.org/blog/?page_id=215
    http://www.andrewkilpatrick.org/blog/wp-content/uploads/2008/07/spdif_circuits.gif
    OTOH, you can get official s/pdif receiver connectors and
    ICs for a few bucks, and that seems a bit more professional.
  2. Winfield Hill wrote...
    Check that, s/pdif's biphase mark code is more than
    close enough to a 50% average for good RC coupling.
    http://en.wikipedia.org/wiki/Biphase_mark_code
  3. Grant
    Grant Guest
    Averages 50% in the longer term, that's why it's an AC coupled signal.
    Yes, but there's more to life than doing everything efficiently ;)
    Grant.
  4. In the following schematics page 17 upper left corner, you see a working
    solution (I have the eval board, its working nicely in coax SPDIF mode).
    http://focus.ti.com/lit/an/slea035a/slea035a.pdf
    MIKE
    www.oho-elektronik.de
    OHO-Elektronik
    Michael Randelzhofer
    FPGA und CPLD Mini Module
    Klein aber oho !
    Kontakt:
    Tel: 08131 339230
    Usst.ID: DE130097310
  5. M.Randelzhofer wrote...
    It's interesting that TI picks an 'U04. An 74LVC2GU04
    to be exact. They do use this simple ac-coupled-circuit
    in a PurePath Digital reference design for their rather
    sophisticated custom silicon for high-performance audio.
  6. Jim Thompson wrote...
    Right, I'm well aware of that. Old stuff, dating back to
    the 60s when I started using cmos, or COS/MOS as RCA called
    it back then. But the question was about the viability of
    non-U types for this, do you have an opinion about that?
    Not what's naturally best, but whether it'll work OK.
