SPDIF to AES/EBU
Discussion in 'Electronic Design' started by Dirk Bruere at NeoPax, Mar 2, 2010.
  1. JosephKK
    JosephKK Guest
    I figure all that needs done is to put it through a transformer to adjust
    for native impedance and use Cat5e.
  2. Thanks - a slightly different approach to the one I was thinking about.
    The SPDIF input goes into a 485 differential receiver.
    You think that would work reliably given the low SPDIF voltage?
    If so, I could just do a 485 diff i/p straight through to a 485 diff o/p
    feeding 3 xformers (I need a 1 to 3 fanout, isolated)
    Dirk
    http://www.transcendence.me.uk/ - Transcendence UK
    http://www.theconsensus.org/ - A UK political party
    http://www.blogtalkradio.com/onetribe - Occult Talk Show
  3. JosephKK
    JosephKK Guest
    Run the signal through an old uA703 diff amp to three transformers.
    Better, use a modern diff amp. 0.6 V and less than 5 Mpbs is easy
    these days.
