SPDIF amplifier
Discussion in 'Electronic Design' started by Dirk Bruere at NeoPax, Mar 1, 2007.
  1. It will be feeding into SHARC based equipment that will do the
    reclocking along with a whole bunch of stuff.
    I can get them for around $5 each, one off.
    Here's an expensive version:
    http://www.maplin.co.uk/Module.aspx?ModuleNo=46790&criteria=transformer&doy=5m3
    Dirk
    http://www.onetribe.me.uk - The UK's only occult talk show
    Presented by Dirk Bruere and Marc Power on ResonanceFM 104.4
    http://www.resonancefm.com
  2. burp/belch/fart and inwardly digested
    T. Giesberts from Elektor Electronics magazine July/August 1995 pages
    78-79. The transformer T1 is made to G2.3-FT12 ferrite ring core.
    Primary coil is 15 turns of 0.5 mm diameter enamelled copper wire and
    secondary is 3 turns of 0.5 mm diameter enamelled copper wire.
    your local transformer dude could save you a some.
    (stolen from http://www.epanorama.net/documents/audio/spdif.html )
    martin
  3. I've looked at those circuits and don't feel too happy about feeding a
    signal that could only be 0.2V (or even less?) into an HCU04
    Dirk
  4. Yabut... they/he uses the 04 in a linear mode, note the feedback
    resistors
    martin
  5. I don't know enough about how the device is specced (from all
    manufacturers) to be confident it would work as a manufacturing solution.
    Dirk
