SOURCING POWER SOCKET
Discussion in 'General Electronics Discussion' started by THUNDERBOLT, Mar 16, 2013.
  1. THUNDERBOLT
    THUNDERBOLT
    22
    Aug 29, 2010
    Just a very simple question I hope.
    I'm trying to replace a 3.5mm DC power socket on a rechargeable torch.
    Every single dimension agrees completely with this:
    http://www.zirui.net/power-socket/DC-003.html
    apart from the pin diameter.
    Having said that, the drawing shown on the attachment shows in the table Ø1 and Ø1.3
    Does that suggest a stepped pin, rather than two versions of the same component?
    The centre pin which snapped off my socket measures Ø1mm exactly.
    Another quite similar component
    http://www.vr-elec.com/product/plan_img/DC022-PA66.pdf
    also has some ambiguity regarding the centre pin size.
    And this one specifically says Ø1.3mm
    http://www.ebay.co.uk/itm/Technic-T...al_Components_Supplies_ET&hash=item3a7bcb39a9
    Can anyone throw any light on their numbering convention and the actual centre pin diameter?
  2. shrtrnd
    shrtrnd
    3,822
    519
    Jan 15, 2010
    There are several sizes of barrel diameters and pin sizes for this type of connector.
    They're all pretty common.
    Just find the one that fits your application.
  3. THUNDERBOLT
    THUNDERBOLT
    22
    Aug 29, 2010
    The problem is I don't want to order the parts just to determine if they fit or not.
    I prefer to know before ordering, especially if there is a minimum order of 10 parts.
    The attachment below, is also somewhat ambiguous. The only body that suits a mating plug of Ø1.1 is a 201, but mine is definitely a 211/212/215 type body, and the mating plug I have is definitely a Ø1.1 bore
    http://cablesandconnectors.com/PIX/phi201.jpg
