Source /Sub for SV-3a Diode
Discussion in 'Electronic Repair' started by Bob T, May 12, 2008.
  1. Bob T
    Bob T Guest
    I have a marantz 4230 receiver with a blown amp
    looking for a SV-3a temp compensating diode (or an entire amp board)
    Can I use any temp compensating diode or is there something I should be
    looking for
  2. Bob T
    Bob T Guest
    thanks the only thing odd I noticed is that the SV-3a diode doesn't look
    like a diode using a dvm. i.e. looks open in either direction
    They do look like diodes when I put them on my huntron tracker which had me
    wondering if there were two devices in the case or something that might
    raise the forward voltage drop
    I have a few diodes from a old scott receiver that I'll try and see what
    happens
  3. Bob T
    Bob T Guest
    Thanks that's it I found a spec for the replacement and it had a forward
    voltage drop of 1.2V
    I put a pair of series connected 1n2002's and it seems to be running fine
