source for can electrolytic caps??
Discussion in 'Electronic Repair' started by Boborann, Apr 1, 2006.
  1. Boborann
    Boborann Guest
    I just got a 60's era jukebox in need of caps Most of them are tha alumminum
    cand that mount on the chasis with valuse like 1500 uf 50 V
    Can somebody point mne to a source of these I would like to keep it looking
    original if possible and would rather not put in caps meant cor a PCB
    BOB
  2. DaveM
    DaveM Guest
    A few reliable sources:
    http://store.triodestore.com/index.html
    http://www.angela.com/catalog/
    https://secure.tubesandmore.com/
    Dave M
    MasonDG44 at comcast dot net (Just substitute the appropriate characters in the
    address)
    Never take a laxative and a sleeping pill at the same time!!
  3. Guest
    BOB:
    The top of the chassis mount "can" electrolytics usually are just
    dried up and as long as they are not shorted or have excessive
    electrical leakage you do not have to remove them or disconnect them
    thus preserving the original look... and can connect "modern"
    electrolytics under the chassis to the "can" electrolytic terminals.
    The modern caps are so much smaller in the last several years and can
    easily be mounted under the chassis.
    electricitym
  4. JK
    JK Guest
    Yes mount new individual caps under the chassis.
    1. The cap cans available these days are possibly old stock, which
    could be leaky already.
    2.They are also quite costly.
    3.Designs and dimensions may not match up to the holes in your chassis.
    Best to disconnect the power supply wiring from the old cap can in case
    of a future short, mount new caps so they share the original ground,
    and sometimes a terminal strip helps for the hot leads. Zap straps to
    hold the new caps in place are sometimes handy. Be sure to order
    polarized caps. Make sure the fuse is rated correctly no more than 2
    amps, possibly 1 or 1.5 amp slo-blo. It's all about protecting the
    power transformer ($$$$).
    JK
  5. Lynn Coffelt
    Lynn Coffelt Guest
    Or, as some nuts are pretty good at, is opening the old can, gutting it, and
    stuffing it with a fresh new electrolytic, which is most likely small enough
    to fit right in!
    Old Chief Lynn
  6. Boborann
    Boborann Guest
    Thanks that sounds worth a try
  7. G
    G Guest
  8. Ken Layton
    Ken Layton Guest
    Yes, Antique Electronics (www.tubesandmore.com) has some brand new
    fresh stock can "FP" style capacitors.
  9. g. beat
    g. beat Guest
    Bob -
    Tim Reese - replacing electrolytic in old gear
    http://www.nmr.mgh.harvard.edu/~reese/electrolytics/
    Phil Nelson's DIY web page
    http://antiqueradio.org/recap.htm
    Antique Radio Supply has access (may have purchased) the Mallory "FP"
    electrolytic "can" production equipment. So they make the more popular
    values.
    Photos for "restuffing the old cans with new capacitors
    http://www.thecompendium.net/radio/filtercap.htm#Drake
    http://www.wb4hfn.com/DRAKE/DrakeArticles/TechTips/FilterCapacitorRebuilding.htm
    http://r-390a.us/filter_capacitors.htm
    Rebuilding paper capacitors (Smithsonian level of restoration)
    http://www.earlytelevision.org/cap_replace.html
