A
Abstract Dissonance
I'm trying to use my sound card as an oscilloscope but for some reason it
just won't work.
I have a variac hooked up to a breadboard and basicaly just running into a
voltage divider and from that into my sound card through its line in jack.
I can control the amplitude of the wave form pretty easy by controlling
either a variable resistor or the variac... the problem is that that the
wave form looks like crap and I can't rectify it in any way(I put a
rectifier as the first component).
Heres a shot of the oscilloscope:
http://www.geocities.com/abstract_dissonance/osc.JPG
It does the exact same thing when I put a rectifier in except if I but it
backwards then it does nothing.
I've used several resistor ratios from 10M's down to 50k but nothing seems
to work. I'm not sure if it has something to do with the sound card(it
should have no problem sampling 60hz mcuh better than it is?) or if its just
the wave form is crap cause of the variac or what ;/
Anyone have any ideas?
I was thinking about taking an old pc monitor I have and trying to hack an
oscilloscope from it(I don't need anything fancy, just need to displace the
waveform)... Is this to much work?
AD
just won't work.
AD
