sony walkman model WM-AF56 repair help
F0X
Jan 16, 2018
Jan 16, 2018
I have a sony walkman radio cassette player that i am trying to repair. The belt for the cassette player is broken and i have the correct parts ordered to fix it. Another issue it has is that no sound comes from the headphones when listening to the radio. I am trying to find the circuit board schematics so if i have to replace any of the components on the board and also need help with testing the components that are on the original board to see which ones need replacing. I have found very little about this model online and need some direction in where to look. Thank You
kellys_eye
Jun 25, 2010
6,514
Jun 25, 2010
6,514
Googling "WM-AF56 Schematic" brings up a couple of sites that have the technical manual as a paid download which, if you want to do your own servicing, would be an essential requirement.
Armed with this and some test equipment (you'll need a multimeter as a minimum and a signal generator and/or oscilloscope as a worst case) we should be able to talk you through the process of fixing it.
73's de Edd
Aug 21, 2015
3,613
Aug 21, 2015
3,613
Sir FOX . . . . .
FOOLISH . . . not to replace the pair.
Since, usually . . . so goes one belt being limp / or / breaks . . . soon . . . . so goes the other .
MECHANO- INFO . . . . .
73's de Edd
73's de Edd
Aug 21, 2015
3,613
Aug 21, 2015
3,613
Therefore if the tape is playing, power is getting to the tape section and also to the audio power amplifier and earphone connections are good.
For the RADIO aspects check out the marked power path below . . . .
SONY SCHEMATIC REFERENCING . . . .
73's de Edd
