sony vcr slv-se727
Discussion in 'Electronic Repair' started by Bram Stolk, Mar 26, 2005.
  1. Bram Stolk
    Bram Stolk Guest
    this VCR acts funny, I cannot get it in REW or SEARCH backward, when the
    reverse functions are activated it spools forward...
  2. JANA
    JANA Guest
    Check the idler tire on the idler wheel assembly. This is located between
    the two reels under the carriage assembly. It is good practice on an older
    VCR to change all the belts, idler tire, and pinch roller. At the same time
    it is good to do a cleaning of all the guies, rollers, and heads.
  3. pertnoy
    pertnoy Guest
    Check the modeswitch.
  4. Bram Stolk
    Bram Stolk Guest
    that's good thinking, Ill go for the modeselectswitch timing as the
    SLV-SE727 has no idler tires
