Sony TV Techs
Discussion in 'Electronic Repair' started by Leonard Caillouet, Nov 2, 2003.
  1. Do a google search for Q601, Q602, 2SC4834, etc and you will find the issue
    has been discussed many times in great detail. There are many differing
    views so read a lot.
    The bottom line is that you need to understand the power supply, deflection,
    and flyback circuits, how they work and how they fail, need to obtain the
    training info from Sony, need to be very thorough in troubleshooting,
    testing, and repairing these circuits, and need to use good quality parts.
    After you do some homework and more checking, post more information and
    there are several guys here who have lots of experience with these and can
    give you more specific help.
    Leonard Caillouet
  2. any sony tv techs around ??
    got a sony kv-32ts46
    it is dead
    replaces the trans q601 and q602 still same prob
    also replaced horz output
    anybody got any info or feedback
    thanx
    howard
  3. Jerry G.
    Jerry G. Guest
    This is very complex to discuss over a simple email. These Sony sets are a
    challenge to even the experienced Sony techs. Usually when there are
    failures in the horiz output, there are also failures in the power supply.
    Sometimes there area also failures in the protection circuits itself. If
    one or the other is not properly serviced, the total failure will occur
    again, on an instant. For many of the parts in the Sony sets, very high
    quality and properly rated parts are required. It is strongly recommended
    to use only Sony original parts in your set.
    Greetings,
    Jerry Greenberg GLG Technologies GLG
    WebPage http://www.zoom-one.com
    Electronics http://www.zoom-one.com/electron.htm
    it is dead
    thanx
    howard
