sony tv defect, no channels anymore
Discussion in 'Electronic Repair' started by Claw, Aug 12, 2003.
  1. Claw
    Claw Guest
    My sony KVA2531 tv suddenly refuses to skip to the channel I choose. Instead
    of the channel of my choice I receive the video-channel each time I press te
    number. Is there a simple solution or should I buy a new tv.
    I searched inside for something that looks like a battery. I once had a
    similar problem with an other electronic device and replacing the battery
    inside solved the problem.
    Is there a memory battery inside a tv?
    If so, what does the battery look like?
    If not, what can cause this problem?
