Sony TC135SD cassette recorder
Discussion in 'Electronic Repair' started by harryhomer, Jun 21, 2013.
  1. harryhomer
    harryhomer Guest
    Just rebelted my cassette recorder. What used to be an occasional thumpingin the left channel is now there all of the time. It almost sounds a little like motoroboating, but maybe a higher frequency. If I push the stop button and hold it down, it goes away temporarily. Sometimes there is a little bleed of that into the right channel; but always predominately left channel. Would this be a bad cap in the power supply only affecting one side? I do have a schematic diagram for this unit.
  2. Chuck
    Chuck Guest
    It is the record playback switch. If you can find one, replace it. If
    not, Deoxit 5 squirted into the switch might repair it. This doesn't
    work 100% of the time. It was such a common problem back in the day
    we used to stock piles of replacement switches for all brands. Chuck
  3. Jamie
    Jamie Guest
    Check the shielded wire from the heads, make sure the shields are
    still connected.
    Also, make sure the PC boards are firmly screwed down to the chassis,
    the post many times have ground pads on them. You need to make sure
    all bypass caps are still connected to ground..
    Jamie
  4. N_Cook
    N_Cook Guest
    thumping in the left channel is now there all of the time. It almost sounds
    Agreed on that
    As its such a work up to desolder these to disassemble and clean or even
    replace. One last resort is to melt the solder points , in turn and with a
    needle inserted in the hole , put a set on the common pins of each switch ,
    so a different area of the contacts is used.
    Sometimes its possible to remove the covers of these switches by bending or
    cutting the tangs under the paxolin and removing , then cleaning the
    contacts individually , and replacing the cover as best as possible.
    Problem tends to be either compacted grease or build up of copper sulphide
    insulating corossion
  5. harryhomer
    harryhomer Guest
    Thanks all. I had long suspected it was one of the switches, but wasn't sure how to proceed; will investigate the approaches presented and let you know how I make out. Thanks again!
