This is an old receiver... probably originally purchased in 1998. Has worked wonderfully its entire life.
I just moved (short move... 25 miles). I moved it reasonably carefully... with my PC and not much else... on the floor of the car and then into a garage. The unit was stored in a clean/dry garage for a month or two. Now I'm connecting it back up again and the left channel is not pushing sound. I have lived in a dry climate for the last six years...
Troubleshooting:
I popped the top and am not seeing anything obvious... although I don't even know what to really look for... I'm not seeing any broken soldering or anything like that. It is quite dirty in there as I've never opened it up.
Any ideas would be much appreciated!!!
Troubleshooting:
- I'm using the tuner to eliminate the possibility of bad cabling or components.
- I'm listening through headphones... same symptom as with speakers.
- The balance control seems to work, as I can fade down to nearly no sound if I turn the balance nob completely to the left
- Volume nob is working and does not affect the left channel... no crackling.
