M
Main Account
I got an old 5.1 Sony STR DE-425 (doesn't have a 5.1 decoder inside) which I
mainly use as a stereo receive. Some couple of weeks ago I connected it to
the 5.1 output of a DVD player and found that the center channel acts like
it only reproduces "half" of the sine wave... if you know what I mean. Took
the cove off and noticed that it uses an STK 350-230. Don't have the
schematic of this amplifier nor the pin layout for the IC to test it
properly but while looking at the back of the circuit board I touched the
IC's pins close to the right hand side of the circuit (holding it in your
hand, looking toward front side with the pins pointing down...) and the
problem vanished. Took my finger off and the sound went bad... As long as I
keep my finger on the circuit board the thing works properly but I can't
keep my finger there all time...
I was thinking to buy a new IC (if I can find one...) but this "magic
finger" issue brought a new question: what if the IC is ok, something else
(like a capacitor for example) causes the problem? Replacing the IC may not
be a solution. Any thoughts?
....SM
....SM
