Sony SLV-D900 VHS/DVD player acting strange.
Discussion in 'Electronic Repair' started by Jack, Sep 3, 2005.
  1. Jack
    Jack Guest
    Turning on the power, the display flashes different characters, dvd will not
    eject, VHS tries to load tape, eventually it turns itself off.
    Did not find any tips for this fault. Does it seem familar to anyone?
    Jan
  2. I think I would start with the power supply, looking for low or poorly
    filtered voltage(s). Also would check solder connections, resoldering where
    indicated, and reseating various plugs and connectors.
    After which the thing would probably wind up in the scrap heap.
    Mark Z.
  3. Jack
    Jack Guest
    Three high ESR capacitors in power supply. Now it works.
    Thanks.
    JMK
