Sony SLV-900HF VCR
D
Daniel Rudy
I have a Sony SLV-900HF VCR where the pinch roller has worn out. ANyone
know where I can get replacement parts? Thanks.
Daniel Rudy
Email address has been base64 encoded to reduce spam
Decode email address using b64decode or uudecode -m
Why geeks like computers: look chat date touch grep make unzip
strip view finger mount fcsk more fcsk yes spray umount sleep
JANA
Get in touch with Sony parts, or one of their parts dealers. We used to get
a kit from Sony that consisted of the pinch roller, idler wheel, head
cleaner sponge, and the belts.These are all standard wear parts that should
be changed during the general maintenance.
You will probably find that for VCR's replacement parts are starting to
become difficult to obtain. Many of the manufactures are no longer
supporting VCR servicing.
JANA
_____
Daniel Rudy
M
Mark D. Zacharias
get
should
JANA
_____
Daniel Rudy
A new pinch roller should probably be available - but my experience has been
that a new one may actually work worse than the old one - they can be that
finicky, in combination with the capstan wear factor.
Mark Z.
M
Mr. Land
If you can't find a replacement, there are rubber reconditioning
chemicals available, might be worth a shot.
S
sofie
Mark
Yes... you are quite correct with your response. If the capstan bearings
are worn, loading arms and guides are worn or bent, tensions are not
correct, etc, etc..... a new pinch roller may not solve all the undisclosed
problems that the OP did not mention.
D
Daniel Rudy
At about the time of 2/15/2006 8:26 AM, Mr. Land stated the following:
I did eventually find the part and order a replacement. We will see how
that works.
I did try the rubber rejuvenator and it worked, for about a week. The
problem is that the VCR curls one edge of the tape. As the tape is
pulled through the deck, it seems that the pinch roller isn't grabbing
it very well.
Daniel Rudy
