Sony SLV-795HF VCR Error Code
Discussion in 'Electronic Repair' started by Sofa Slug, Nov 27, 2006.
  1. Sofa Slug
    Sofa Slug Guest
    I'm trying to repair this VCR...
    If you enter stop or play while the machine is in fast forward or rewind
    (or allow it to go to the end of the tape and stop by itself), the deck
    will stop and a motor (loading motor?) will run for a few seconds, then
    the deck will shut down and display the error code "3L 10cc". Does
    anyone know what this error code refers to?
    If you wait for 10 seconds more, the machine will reset & work until it
    has to stop in fast wind again, then it will go back into the same
    failure mode. Tape will load, play, and eject correctly when not in
    failure mode.
    Mode switch removed, cleaned, and replaced - did not fix problem.
    Any help appreciated...
