S
Shawn Lin
I have a Sony SLV-686HF that won't rewind.
High speed rewind results in the tape being loaded/unloaded repeatedly
until the VCR gives up and quits.
Normal rewind results in the tape rewinding for anywhere between 3 and
30-seconds before the VCR just quits.
Reverse scan during playback doesn't work either.
Fast forward works.
Playback works fine.
The load arm is fully lubricated and moves freely.
The capstan motor flywheel was previously rubbing on the windings,
causing stop & go playback operation as well as severe binding. With
pliers and vise-grips, I carefully bent the vertical part of the
housing to where the flywheel no longer rubs the windings and spins
freely. That completely fixed all playback issues. I just wonder if
the damaged windings has resulted in a weak motor that cannot supply
the torque required for rewinding?
Has anyone encountered this before and know the cause?
Shawn
Fast forward works.
Shawn
