C
Chris F.
I service beta VCR's for resale, and right now I've got a Sony SL-810D
that's driving me up the wall. When I acquired it, it was totally dead.
Replacing the STK regulator on the power supply got it going, but the tape
would only operate in reverse (even when it was supposed to be playing
normally) and was also going way too fast. I replaced the capstan motor with
a known-good one, this restored the correct bi-directional function, but the
speed issue remains. When in normal playback mode, the tape runs at near
fast-forward speed. When in slow-mo, it runs at just above normal playback
speed. Pause, fast forward, and rewind work normally. The capstan free speed
adjust potentiometer does have some effect, but doesn't bring the speed
anywhere near within range.
The problem is present both during playback and record, and it correctly
senses BII or BIII recordings, ruling out any issues with the A/C head or
associated circuitry. I've spent countless hours pouring over the service
diagrams, and have swapped numerous IC's from the ST-18 board with
known-good ones from another VCR, all to no avail. I've also checked all the
caps in that area for ESR.
Without a thorough knowledge of VCR design, all I can do at this point is
swap parts. I thought I had enough skill, but I cannot grasp enough of this
particular circuit design to effectively troubleshoot the problem. A good
place to start would be knowing where to find the reference voltage or
signal that determines the overall capstan speed.
Can anyone give me any ideas, or better yet, does anyone have another one
of these units for parts?
