Check the pico fuses on the "G" power board and on the "D" deflection
boards. If either of the 5 amp are blown on the "G" board then you are
fairly certain the STK devices on the "D" board are failing. Then check the
3 amp at the STK devices and change both of ics. The pico fuses on the "D"
board are the main protects for the +/- supplies to the STK ics.
As Leonard noted, try to get a better idea of the symptom, may even be
failure of the actual blue crt causing shutdown, a very common problem on
the RA-6 and DA-4 chassis. BTW these blue tubes are no longer available, may
find a source at VDC to rebuild the original. Finding he blue tube defective
it is highly recommended to also check the green and red tubes, lightly
tapping the neck of the crt and watching a blank raster [unused video input
works well] to see if there is any flashing exhibited on screen while
tapping on the crt necks. Some of the green crts are also becoming nla so be
sure to check availability.
