Sony Projection TV - from light to dark
Discussion in 'Electronic Repair' started by b e, May 23, 2008.
  1. b e
    b e Guest
    I have Sony projection tv that has been moved three times. The first
    time is was moved a color gun went out. It was under an extended
    warranty at that time and was replaced and worked perfectly after
    that. One year ago I moved again. A month or two after moving the
    set began to go from an excellent picture to a very dark picture. The
    color does not change but everything becomes much darker. I have
    changed all settings to the brightest and sharpest. I don't know if
    this is something a layman can fix or if I have to have a professional
    do the work. I would appreciate any incite someone could give. Thank
    you in advance.
  2. hr(bob)
    hr(bob) Guest
    You do not say how old the set is or a model number, But, if it was a
    month after moving that the picture started to get darker, I doubt
    that the moving had anything to do with the problem. That would have
    shown up immediately.
    If you have increased the brightness to its maximum, there is nothing
    more that you can do. If the set is more than a few years old, it
    will probably cost more to fix than to by a new LCD set.
    Bob Hofmann
