SONY PLASMA PROBLEM
Discussion in 'Electronic Repair' started by FUTURETECH, Nov 5, 2004.
  1. FUTURETECH
    FUTURETECH Guest
    The unit turns on and then goes into StandBy Mode.
    SONY PFM-42B1
    Any ideas on what might be causing this and if this is a major costly repair
    or not.
    thanks
    TIM
  2. The unit turns on and then goes into StandBy Mode.
    Is the set still under warranty? - Reinhart
  3. Bill Jr
    Bill Jr Guest
    Count the number of times the led flashes.
    If it does 6 flashes between pauses the write it off.
    Good Luck,
    Bill Jr
